0 members (), 102 guests, and 3 robots.
Topics128,186
Posts1,057,319
Members48,469
1 Offline
I swapped out the front cross member on my 1946.5 Chevrolet 3/4ton with a GMC cross member and dropped a 270 in yesterday. Since it brings it out an inch and a half I'm working through the sheet metal problems, as well as moving the radiator forward. I was wondering if there was anyone here that has done this? Looks like I will need to take some of the radiator support out to bring the hood down. Pushing it forward means the hood is too high. And cut the upper baffle back 2 inches or so. But if there is someone that has done this I would love to talk it over before I cut too much.
Trombones Totem Poles And Old Trucks!
In my 46 hotrod I had to move the radiator 2 inches forward. I only moved the radiaror not the frame. I made spacers to move it and remount it. I had to modify the sheetmetal piece that is just forward and above the rad. My rad is not a stock rad and is shorter than than standard. I think my 41 gmc has the rad moved forward also. Dave
1941 Chevy
"First rebuild - complete!"
Follow the story in the DITY
1941 GMC resting peacefully
1946/1947 Chevy Street rod on s10 frame complete
1945 GMC panel truck in line for restoration
1941 Plymouth stock complete
1941 GMC COE in restoration process
Read his Project Journal
1941 Chevy Coe uncertain future resting now
back yard wrench turner
I put a 270 in my '38. I moved the radiator forward to the front of the cowl. I did have to modify the top piece of sheet metal, but the hood closes without issues. I'm using the stock radiator.
Wayne
1938 1-Ton Farm Truck
Stovebolt Gallery Forums
1989 Silverado
1996 Mustang GT convertible
1 Offline
Thanks! I abandoned the extension plate idea and went with the wood spacer and put the radiator inside the support 1 and 1/2 inches forward. It worked perfect!
