4 members (Lightholder's Dad, Donf, rfs56trk, Forty9), 140 guests, and 1 robot.
Topics128,189
Posts1,057,337
Members48,469
Where do you guys suggest I buy new bushings for my front and rear springs? I just completely tore down my springs and frame and have removed the bushings from the spring eyes, front hangers, and rear shackles.
Liquidated my projects
Now looking for a decent '47-'55.1 3100, 3600, or 3800
I used Espo for most of mine.
1951 1 Ton Completed
I ended up using rockauto. They had everything except the bushings that press into the rear shackle (the ones that are two per shackle and real thin). At this point I think I'm just going to use my old ones unless someone knows where to purchase them.
Are your bushings are essentially a metal tube?
If so I am sure you can get a machine shop to match up the material and make you a set of bushings. Jeffrey
That's a good idea. I will probably end up doing that.
