| | | Forums66 Topics128,195 Posts1,057,372 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2005 Posts: 168 'Bolter | | 'Bolter Joined: Jun 2005 Posts: 168 | Where do you guys suggest I buy new bushings for my front and rear springs? I just completely tore down my springs and frame and have removed the bushings from the spring eyes, front hangers, and rear shackles.
Liquidated my projects Now looking for a decent '47-'55.1 3100, 3600, or 3800
| | | | | Joined: Mar 2002 Posts: 9,115 'Bolter | | 'Bolter Joined: Mar 2002 Posts: 9,115 | I used Espo for most of mine. | | | | | Joined: Jun 2005 Posts: 168 'Bolter | | 'Bolter Joined: Jun 2005 Posts: 168 | I ended up using rockauto. They had everything except the bushings that press into the rear shackle (the ones that are two per shackle and real thin). At this point I think I'm just going to use my old ones unless someone knows where to purchase them.
| | | | | Joined: Jan 2015 Posts: 914 'Bolter | | 'Bolter Joined: Jan 2015 Posts: 914 | Are your bushings are essentially a metal tube?
If so I am sure you can get a machine shop to match up the material and make you a set of bushings. Jeffrey | | | | | Joined: Jun 2005 Posts: 168 'Bolter | | 'Bolter Joined: Jun 2005 Posts: 168 | That's a good idea. I will probably end up doing that.
