7 members (SmalltownTRKGuy, 52Carl, Ponchogl, GradyB, Otto Skorzeny, GRNHydra, 1 invisible),
76
0
Mod | | | Forums66 Topics128,080 Posts1,055,945 Members48,430 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2013 Posts: 36 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2013 Posts: 36 | I want to add a passenger side mirror to my 1961 Chevy C-10 Apache but there are no threaded inserts as on the drivers side. I want to match the stock mirror mount that is on the drivers side. Install inserts? How? Thanks all. | | | | | Joined: Apr 2015 Posts: 336 Shop Shark | | Shop Shark Joined: Apr 2015 Posts: 336 | When I had a driver side mirror installed, I wanted the guy to get a metal plate at least 2x thicker than the door metal, weld nuts to it then glue it to the inside of the door. Then screw the mirror on, which would hold the plate in case the glue failed. What he did instead was drill 3 holes in a plate that the screws would thread into and pop riveted the plate on. The rivets are hidden under the mirror base. NOT my choice. Unless somebody else has other ways, I think those are your 2 options, without finding a door that has factory attachment. Just be sure to place the mirror in the right spot if you use one of the 2 options I gave.
1959 3100 Apache Fleetside
| | | | | Joined: Oct 2005 Posts: 4,252 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,252 | You could always use nutserts. | | | | | Joined: Jun 2013 Posts: 36 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2013 Posts: 36 | | | | | | Joined: May 2005 Posts: 1,624 Shop Shark | | Shop Shark Joined: May 2005 Posts: 1,624 | The nutsert I have will not work with the thickness of the door skin alone. On the other hand if you did as Cablemill suggest and add a plate inside the door, then joined the two together with the nutsert with the holes aligned for the mirror. That might work. The PO of my truck replaced the cargo mirrors with just one aftermarket on the driver's side and it flexes. I want to add a matching one to the passenger door and stiffen up the drivers. Thanks guys, I can do this.
| | | | | Joined: Oct 2005 Posts: 4,252 "Hey! I sound like Darth Vader!! | | "Hey! I sound like Darth Vader!! Joined: Oct 2005 Posts: 4,252 | If you have access behind, you can get some 3/16" minimum plate, contour it to the inside, drill and tap it.
There's always more than one way to do a job. I'm not too proud to use a masking tape to hold something in place until the bolt starts threading. | | |
