2 members (Steelonsteel, Wooley), 141 guests, and 2 robots.
Topics128,167
Posts1,057,020
Members48,458
Apprentice
Apprentice
Trying to restore stock '54 3100 steering wheel. 3 Qustions: 1. Is it advised to open up the crack to get plastic to adhere better? 2. What type of, or brand of plastic filler is recommended? 3. What type or brand of paint is recommended?
Jon
Nashville, TN
Eastwood sells a nice book on steering wheel restorations.
question 1. Yes
1954 GMC De Luxe COE
Regular plastic body filler will not work on a steering wheel. There are kits sold by the usual suspects to do this; try Chevy Duty: Steering Wheel Repair Epoxy. Part No. 32-391. Price $6.95.
Good luck.
~ Kimberly
My '54 ... and my '63 and a '59 F100
Z
Z Offline
eastwood also sells a repair kit.
I'd imagine that any semi-flexible epoxy repair material would work. I have some stuff made for repairing plastic bumpers that looks like it should work.
I used this stuff that's just called "epoxy" i think it's for bonding rear view mirrors & glass back into mirrors but it holds tight. After i just used fine grit sanding paper, painted the wheel it's copy of original colors, & then clearcoated. All of which was cheap spray/rattle cans but worked Verrry nice I think.
"MONGO"
"MONGO"
Just read a tech article on another board where the guy used POR putty from the POR15 people. Looked like it worked pretty good, he also recommended several layers of primer with sanding in between before painting. So I picked up some of the POR putty at the shrine swap last weekend, got a couple wheels I wanna work over.
MONGO
Mongo's Garage
Vintage GM Truck's & Parts
https://mongosgarage.com
Hey KC have you used POR15 before? I have seen their ads but yet never have actually met anyone who's used it, seems like if it works as good as they say everyone would be using it... but I cant seem to find anyone who has. (imagina that)
Anyways, if you've used it or know someone who has, what was the results and would you/they recommend it to a friend?
thanks
Boogity, Boogity, Boogity Let's go racin boys.
Drive fast, turn left. GO #20.
Real trucks where bowties.
Apprentice
Apprentice
1 Offline
Got to Car quest and buy two part JB quik . I restore steering wheels all the time and it works the best
1bad58
Apprentice
Apprentice
1 Offline
In regaurds to Por 15 It is only a cover up .The only way to stop rust from showing is to sand blast it use self etching Dupont primer and paint it. Amature restorers like to cover it up with por 15 and Rust stop products.
1bad58
