8 members (Mike B, WICruiser, Youngin' Tut 59, Pete1946, Bizaircon, klhansen, LuckyLee, 1 invisible), 72 guests, and 1 robot.
Topics128,140
Posts1,056,770
Members48,454
I have a '58 3200 with factory electric wipers. I have tested the motor and everything is great. I now need to wire it to the truck. I have the switch which grounds two wires for high and low speed operations. What I need to know is where the hot wire that goes directly to the motor would have tied in. The Factory Assembly Manual has a page for the '55-'57 electric wipers that are different from the '58. The '55-'57 pulls the hot from the hot side of the ballast resistor. That makes sense since it is probably the closest to the wiper motor and only on when the switch is on. However, it is not fused. I don't see a location on the fuse panel for wipers. Any idea how a '58 with factory electric wipers was originally wired?
Chad
if you have the 58 shop manual supplement, there should be a section about wipers in it - the factory fuse panel has a position labeled "ACC" [accessories], use it for power
Big Bolt Forum Moderator
the wires that come out of the wiper motor go to terminals on a board right on the wiper motor frame assembly. There should be a male spade terminal on that for the hot wire to plug onto. I think I can get a picture if needed but there should only be one terminal to plug the hot wire onto.
Mike
Thanks guys.
I do have the shop manual, but I haven't checked it yet. I will take a look.
69Cuda, I have all the connectors on the board and have tested everything. I was specifically interested in where the wire that connects to the board for hot connects to the truck. It seems the answer is to use ACC on the fuse panel.
Thanks Again,
Chad
oh, sorry, I was thinking the motor end of the wire! yes, the other end should be hot when the key is on. (in the run or acc position). I am not 100% sure the label of the lug on the key switch.
Mike
