3 members (baldeagle, Shade Baby, 1 invisible), 94 guests, and 4 robots.
Topics128,125
Posts1,056,336
Members48,439
#1171300 06/27/2016 1:06 PM
Rebuilding a 53 Suburban Carryall for my uncle that he started about 12 years ago. He bought as an unfinished project and mostly disassembled. I set the body back on the frame this weekend but not sure about placement of body to frame pads. We have a kit with 4 2"x2"x2" blocks and 4 2"x2"x1/4" pads. Currently we have the 2x2 blocks on the rearmost mounts and the thin pads on the front mounts.
Is this correct?
We have a shop and assembly manual but can't find a clear explanation of where they go.
Thanks!
These photos might help.
The FAM & Shop Manual have very little/no info on this.
That's perfect! Thanks!
Check out this 1954 Chevrolet 3100 Panel Truck Body Mounting Points photo album.
The 1947-55 1st series 1/2 ton panel truck mounts are pretty much the same as the Suburban mounts.
2 rubber pads per wood block, top and bottom.
Wood block location. numbers 3 and 4 mounting points.
There is one rubber pad at all the remaining mounting points, in between the body mount and the frame.
Numbers 1, 2, 5, mounting points.
Click magnifying glass with plus sign on upper right hand corner to enlarge image,
Very nice (and very helpful) photos, Jorb
