| | | Forums66 Topics128,168 Posts1,057,027 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2014 Posts: 48 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2014 Posts: 48 | I just got my 283 back from the shop and while it was there they drilled and tapped the front of the crank for a bolt and washer. This might be a dumb question, but I don't know the answer, so here goes. When I went to install the crank pulley today, I realized that the center hole in the pulley isn't large enough to fit over the bolt and washer. So is it correct to assume that I remove that bolt and washer, bolt the pulley on, then reinstall that center bolt and washer? Thanks!
Matt Blacktop Cannibals Car Club 1954 Chevy mild custom car 1955 Chevy second series 3200
| | | | | Joined: Feb 2004 Posts: 29,868 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,868 | Yes, remove the bolt, and DO NOT attempt to pull the balancer on with the bolt! You'll strip the new threads. There are balancer installation tools available for rent at most auto parts stores, or the balancer hub can be heated with a Propane torch until a drop of water sizzles when dropped onto the hub, then drive it on with a BFH and a block of hardwood. Then install the center bolt and washer with a couple of drops of blue Loctite and torque it to about 50 ft/lbs. Jerry
| | | | | Joined: Feb 2014 Posts: 48 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2014 Posts: 48 | Thought I replied, but don't see my post. Thank you!
