10 members (Gray_Ghost, Nick in Manitou, Gdads51, Jon G, Otto Skorzeny, Hotrod Lincoln, walter74, LAROKE, 2 invisible), 107 guests, and 3 robots.
Topics128,131
Posts1,056,372
Members48,441
#1171364 06/27/2016 6:32 PM
I have a 1960 261 in my '53 3100. It's pretty hot these days and I wonder how much value there is in closing the heater shut off valve to my recirculating heater. Does anyone bother with that in the summer and does it help? Thanks
~Denny
1953 Chevy 3100
w/1960 261 cid, 848 head | Weber 32/36 progressive 2 barrel carb. | Three on the tree & 3:55 torque tube | 12 V w/Gener-Nator & 6 V starter
1998 Chevy Suburban 350 ci awd/4wd
Riding in the Passing Lane
Yes. It is a good idea. It will cut down on the heat in the cab. Be shure & put it in the 5/8 heater hose coming from the therm housing.
1972 Chevy c10 Cheyenne Super
Crusing in the Passing Lane
If it overheats in the summer when you close the heater water valve, need more heat capacity. If it ever overheats when the valve is closed, open it to get a few more miles to water.
Ed
Will do. Thanks, guys.
~Denny
1953 Chevy 3100
