1 members (baldeagle),
31
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,004 Posts1,055,246 Members48,418 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2011 Posts: 264 Shop Shark | | Shop Shark Joined: Dec 2011 Posts: 264 | Finally got the chance to check my mileage yesterday since installing my 5 speed. With a 261 and a zenith carb on a 86 mile drive. A little town and a little highway I came up with 19.93 mile per gal. | | | | | Joined: Dec 2015 Posts: 2,062 Big Bolt Forum Moderator | | Big Bolt Forum Moderator Joined: Dec 2015 Posts: 2,062 | That's great! I'd be happy with half that in my 2-ton! I took it out this last weekend, almost all freeway, 6 mpg. 327 and SM420, but going down the freeway it is spinning 3500-4000 depending on if I keep around 60 or push a bit to keep up with traffic closer to 70! | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | I got 6-9 mpg with my 503 in a 630 for about 600 miles, with a 6.5 rear end ratio.
Ed
| | | | | Joined: Jan 2015 Posts: 914 'Bolter | | 'Bolter Joined: Jan 2015 Posts: 914 | Finally got the chance to check my mileage yesterday since installing my 5 speed. With a 261 and a zenith carb on a 86 mile drive. A little town and a little highway I came up with 19.93 mile per gal. Down hill both ways? Jefffrey
| | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | congratulations, basham
What mode Zenith carburetor? | | | | | Joined: Dec 2011 Posts: 264 Shop Shark | | Shop Shark Joined: Dec 2011 Posts: 264 | If memory is correct it's a 11965 | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | 11965 was used on 1957-1961 270 GMC engines.
That would be a nice match for a 261.
| | | | | Joined: Mar 2003 Posts: 1,132 Shop Shark | | Shop Shark Joined: Mar 2003 Posts: 1,132 | Wish I could get that MPG with my 283. Mine is closer to 11/12. I have the tendency to reduce gas mileage claims by 25 per cent to get realistic. Just sayin.
Weeds | | | | | Joined: Aug 2006 Posts: 486 'Bolter | | 'Bolter Joined: Aug 2006 Posts: 486 | What model truck is that in? Seems to be a good combo.
'64 swb stepside (gone) '57 1 ton '53 phone truck '59 swb '46 1 1/2 ton '68 swb gmc
| | | | | Joined: Dec 2011 Posts: 264 Shop Shark | | Shop Shark Joined: Dec 2011 Posts: 264 | 1953 half ton with 390 rear end
| | | | | Joined: Dec 2015 Posts: 2,062 Big Bolt Forum Moderator | | Big Bolt Forum Moderator Joined: Dec 2015 Posts: 2,062 | Wish I could get that MPG with my 283. Mine is closer to 11/12. I have the tendency to reduce gas mileage claims by 25 per cent to get realistic. Just sayin.
Weeds WAIT, Don't take 25% away from my 6 mpg... I'll hardly be able to get up to freeway speeds before I need to stop for gas! LOL... On a side note, I bumped my iming up 2 degrees and kept the speed down (mixed in some mom-freeway driving) and got 8 mpg on the last tank. Anyone know how much engine temp affects gas mileage? My engine does not have a thermostat (or it is stuck open) I need to pull it apart and put one on when I replace all the hoses. | | |
