5 members (Bill Hanlon, artinva, Hotrod Lincoln, RoadsScholar, 1 invisible), 98 guests, and 1 robot.
Topics128,078
Posts1,055,936
Members48,430
#117109 07/27/2005 5:49 AM
I'm just about ready to spray my upper cab with acrylic enamel. I've spent the last two weeks prepping drip rails, welding holes, grinding and sanding. I took everything down to bare metal, used a phosphoric acid metal prep, applied 3 coats of Rust Bullet to drip rails, then sprayed a few coats of etch primer. The last coat of etch primer went on this morning along with some seam sealer around drip rails.
I'm planning on doing 2 coats of flat white Dupont tomorrow. Then 2 more on Thursday.
So, did I miss anything? Or am I ready for top coat? Sealer over the etch primer? Anything between the etch and top? Just shut up and shoot?
-David
Tradin' up dimes for nickels...
My \'65 Chevy C-20
#117110 07/27/2005 6:08 AM
take yer pick grin did you do any sanding on the primer? use a primer-surfacer? I'd use at least a sealer, but then I'm not a painter either
#117111 07/27/2005 6:15 AM
I'm gonna sand just a tad before the enamel. It's actually pretty good. I was planning on letting it sit over the weekend and then wet sanding top coat next week.
My \'65 Chevy C-20
#117112 07/27/2005 6:50 AM
that'd prolly do, but I'd still look into using a sealer, but you should check on what's usual for the paint type/brand you're using
#117113 07/27/2005 7:44 AM
what etching primer did you use? what paint single or bc let me know I took dupont's chroma system class a few years back
with etching primer you need to either primer over or seal over.
DustyG.
1952 Chevy 1.5 ton
1949 Gmc 2 ton flatbed Dump
#117114 07/27/2005 4:48 PM
I used Mar Hyde self etching primer.
Mar-Hyde
My \'65 Chevy C-20
#117115 07/27/2005 6:10 PM
#117116 07/27/2005 7:09 PM
I just went and bought some primer surfacer. Gonna do a couple coats of that and then the white tomorrow.
-David
My \'65 Chevy C-20
#117117 07/27/2005 8:29 PM
sounds good. just make sure that all of your areas around opennnings, edges corners are sanded down. those are the main spots people miss of forget.
DustyG.
1952 Chevy 1.5 ton
#117118 07/27/2005 10:14 PM
White is easy. Just practice on a scrap piece to set up your gun because color never sprays the same as primer.
Paint & Body Shop moderator
#117119 07/28/2005 12:39 AM
Alrighty, will do.
Didn't like that primer surfacer at all. It was VERY dusty. Didn't have any dust problems with the Rust Bullet or the etch primer.
Didn't like the seam sealer either. Had the consistency, look and feel of tub/tile caulk.
Glad to hear white is easy as I'm a bit concerned about jacking things up. I've spent so much time prepping and trying to get this right. You'll see a grown man cry if I've gotta start all over.
Hopefully, I'll get a couple coats of white on tomorrow (after I sand and rinse and clean that darn primer surfacer).
-David
My \'65 Chevy C-20
#117120 07/28/2005 1:42 AM
Get the 3M seam sealer that is two parts, its called self-leveling, works good. Brian
My \'64\'s in the Gallery
Pictures in my Photobucket
1964 C10 Custom Cab 350/700R4
1964 Suburban 350/700R4
1979 Ford F350 4x4 400/c6
#117121 07/28/2005 2:43 AM
Tab Offline
You won't have to start over if you make a mistake on the final coat. In a worst case scenario, you'd have to wet sand the top coat and repaint. That's not a huge deal. A pain in the butt but nothing to freak about. Many painters plan on putting two top coats on anyway. Just make sure that your paint is mixed properly so that it flows out well and check your gun settings before you begin shooting.
delete my account and pictures
#117122 07/28/2005 3:09 AM
V
V Offline
Rule #1 when you have it as clean as possible clean it again.
#117123 07/28/2005 8:13 AM
OK, is there something specific I should paint over the seam sealer with? A guy at work said something about "Bulldog". And then topcoat over it. Does this sound familiar?
Jury's still out on the seam sealer I already applied. Gotta check it in the morning.
-David
My \'65 Chevy C-20
#117124 07/29/2005 2:14 AM
the only thing that I would add to the paint is some flex additive. by dupont code 2350s. then you will never have to wory about cracks on the seams
DustyG.
1952 Chevy 1.5 ton
