| | | Forums66 Topics128,077 Posts1,056,280 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2015 Posts: 36 'Bolter | | 'Bolter Joined: Jul 2015 Posts: 36 | My 55 does not have a fuel filter. Most pictures have filter above manifold before carburetor. I heard this is a dangerous location in case of leaks and fire. Also heard that before fuel pump to protect pump. Thoughts or suggestions? | | | | | Joined: Dec 2001 Posts: 14,522 Moderator: Welcome Centre, Southern Bolters, Legion Hall | | Moderator: Welcome Centre, Southern Bolters, Legion Hall Joined: Dec 2001 Posts: 14,522 | For one thing try to find a place that is easy to get to. personally I think one before the fuel pump is good. Since I can get under my panel fairly easy I put one just after gas comes out of the tank. I've seen many filters before the carb and have one like this on my V8. There is also a filter that Screws into the carb which would help eliminate a hose or clamp malfunctioning and causing problems. Ultimately, the choice is yours. Is your tank in like new condition? are you lines new? All these play a part in decision making.
One last point. If anyone's tank is located where it can gravity feed I'd recommend a cut off valve there for safety. | | | | | Joined: Jul 2015 Posts: 36 'Bolter | | 'Bolter Joined: Jul 2015 Posts: 36 | | | | | | Joined: Apr 2008 Posts: 643 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 643 | I put one before and after my pump. Filters are cheap protection.
Danny 1958 GMC stepside GMC 302 six cylinder 3 speed OD trans
