4 members (tclederman, Peggy M, Cletus1950, Charles in CA), 139 guests, and 13 robots.
Topics128,106
Posts1,056,217
Members48,436
Moderated
Moderated
gonna do a custom restoration on the Ole girl, she currently has the bone stock everything in her from the 235 to the 3.38 geared differentials, I'm looking for suggestions anywhere from color to what wood I should redo the bed out of town if I should rework the old steel panels or if I should replace off of lmc truck, I'm looking to drop a 383 stroker in it pushing close to 400 horse on pump gas and want ideas for what tranny to put between that and the Atlas transfer case, I want gearing that'll take me fast and I can gear down on the Atlas to take her slow, it'll need to be able to handle the torque from the stroker, I'm going carbeurated and want it as simple as possible electrically, give me your ideas, thoughts, I'm all ears.
Are you wanting to run a manual or an auto trans?
I'm a big fan of the NV4500 if you want a manual.
Also, don't forget to go over and post an intro on the 'Welcome Centre' section of the forum. People always like that.
Welcome to Stovebolt!!!
Kyle
"Never tell people how to do things. Tell them what to do and they will surprise you with their ingenuity." - George S. Patton
My Machine
Another vote for the NV4500 for manual. Or 4l80e for auto.
How fast is fast? Im not familiar with axles available in these trucks, do you plan to keep the stock axels? There are online calculators available for gear ratio and tire size. How big of a tire are you planning on running?
How bad is the old steel? I would try to rework it myself. But that depends on your time and skill level.
61 k10 had 3.90 axle ratio. C10 did have a 3.38 ratio
ron
