| | | Forums66 Topics128,141 Posts1,056,485 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2016 Posts: 2 Moderated | | Moderated Joined: May 2016 Posts: 2 | Would anyone know the thread size of the turn signal lever? Thanks. Tom | | | | | Joined: May 2007 Posts: 1,718 Moderator: 60-66 Trucks; North Eastern Bolters | | Moderator: 60-66 Trucks; North Eastern Bolters Joined: May 2007 Posts: 1,718 | Thread? Not sure about threads. If my recollection is correct I used a small screw on my lever. Is my recall that aged or does your lever have a thread? | | | | | Joined: May 2016 Posts: 2 Moderated | | Moderated Joined: May 2016 Posts: 2 | It was gone when I bought the truck a couple weeks ago. I had one from late 60s to 70s, as I remember they were screwed in. I thought some body could take a quick look I would thread a piece of rod rather than pay $25. | | | | | Joined: Feb 2012 Posts: 206 Shop Shark | | Shop Shark Joined: Feb 2012 Posts: 206 | I just looked at the lever on my 65 C20 and it does not appear to be threaded. It seems to be attached to a ring by a bolt between the steering column and the wheel. If you look at the LMC Truck catalog or website you will see what I mean. The lever costs $14.95 at LMC. Good luck.
1965 Chevy C20 Stepside
