Brrrr
place holder
6 members (WICruiser, Maybellene, Rusty Heaps, 55shaker, G508, greenie-reddy), 200 guests, and 2 robots.
Topics128,271
Posts1,058,412
Members48,485
#1170350 06/19/2016 10:35 PM
The brake was most mysterious, sometimes it worked sometimes not. Looked where the pedal shaft exited through floor, found the guide which was originally 3/4" hole was now a 1" hole and all wallowed out. I cut out a piece of steel drilled 3/4", welded it onto existing worn out plate and all is good. BUT....I found my front brake shoe lining cracked in two places...what causes the brake lining to crack? The drum was not scored and the front shoe was ok just the rear shoe lining was cracked in two places...new brakes going on Tuesday at local brake shop?
Steve
Age.
1950 4100 - unrestored and driven weekly for almost no reason at all.
Thanks.....they said bonded are better than rivets in this regard.
Steve
