4 members (1955 1 Series, mason86, moparguy, MNSmith), 103 guests, and 1 robot.
Topics128,068
Posts1,055,883
Members48,428
#1170447 06/20/2016 6:43 PM
Will cast iron crossmember-mounted V8 style bellhousing from a '55 and later truck application also fit in a '47-'54 style frame?
1950 4100 - unrestored and driven weekly for almost no reason at all.
ODSS Lawman
ODSS Lawman
Rather than list every bell housing, what is your truck and what are you trying to install?
SWEET
1950 GMC 450
1951 Chevy 1/2-Ton
The GreenMachine
I'm not trying to install anything. I am only curious if the next gen truck chassis bellhousings will also work in the 47-54 chassis.
Riding in the Passing Lane
Only on the 54. It has a different crossmember then the earlier models. The 54 crossmember can be put on the earlier frame.
1972 Chevy c10 Cheyenne Super
Interesting.
That is interesting, there were many changes that year.
Lots more pictures
Early..47-53 bell housing had "flat" mounts. Sort of true horizontal to the crossmember. 54 the mounts came to be angled tipped down to the center. Same time the V-8 is introduced(265). The company chose to make all the bellhousings and crossmembers fit. Out with the old..and in with the new. The truck had to wait for the steering to move for the wider V-8. But the crossmember was changed. A half step at a time I guess. Like the 55.1 and the 55.2 the truck got a mid year change(new chassis and new sheetmetal) Lots happened at that time. Then, the 285 comes right on top of the 265, same mounts in the early versions.
Steve H
