7 members (Shade Baby, Pete1946, frogfarmer, baldeagle, 1955 1 Series, Jon G, 1 invisible),
97
8
Mod | | | Forums66 Topics128,106 Posts1,056,213 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2016 Posts: 42 Wrench Fetcher | | Wrench Fetcher Joined: May 2016 Posts: 42 | Hi, new recruit here. I recently picked up a 1965 Chevy/GMC daily driver project truck. I'm not sure exactly what truck I have because the VIN and data plate in the cab both say GMC, but everything else outside and inside are Chevy parts. I tried to find the partial VIN on the frame, but didn't locate it. Any ideas? Someone years ago swapped the engine out for a 350 and a newer transmission. They also gave it a poor paint job. Otherwise it's a decent truck and I'm glad to be able to save it and keep it going. [url=http://s61.photobucket.com/user/dernye/library/Mobile%20Uploads?sort=3&page=1&_suid=1466214293796030962662561796606]1965 Chevy/GMC[/url]
'If you want to test out a truck, buy your own dang truck!' -CSM Fulk, Iraq
| | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | 1965 Chevy/GMC]is this it? Direct posting isn't allowed, you have to provide a link.
Bill Burmeister | | | | | Joined: May 2016 Posts: 42 Wrench Fetcher | | Wrench Fetcher Joined: May 2016 Posts: 42 | Sorry, it didn't work like I meant for it to. 1965 Chevy/GMC
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | I gave an answer on your other post. It is a GMC "VIN"/serial no.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Mar 2009 Posts: 788 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 788 | GMC do not hav a ser# on the frame in these years but chevrolet does. sbc is a common swap vs the v6 ron | | | | | Joined: May 2016 Posts: 42 Wrench Fetcher | | Wrench Fetcher Joined: May 2016 Posts: 42 | Ron - is there any truth in the numbers on the outside of the frame under the front of the cab on GMC trucks starting with 2443630? The entire number is 2443630 8 17 77 67. Thanks for the info! Adam
| | | | | Joined: Sep 2010 Posts: 32 Wrench Fetcher | | Wrench Fetcher Joined: Sep 2010 Posts: 32 | It's definitely a Chevy cab. The GMC dash is completely different. | | | | | Joined: May 2016 Posts: 42 Wrench Fetcher | | Wrench Fetcher Joined: May 2016 Posts: 42 | Is the entire dash different, or just the parts on it, like the dash lens and a/c vent? I'm thinking that someone years ago had a GMC that needed lots of body work, had a Chevy parts truck and replaced the body parts. Then probably didn't want mismatched Chevy and GMC parts and swapped out the interior parts also.
| | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | you're fantasizing, there's not much difference in GMC and Chevy "body parts", the difference is in the dash and chassis, and your truck appears 100% Chevy - as I said in another of your threads [should keep things in one place], someone had a Chev with no papers and got a GMC tag and title to use on it, not legal, but not uncommon
Bill | | | | | Joined: May 2016 Posts: 42 Wrench Fetcher | | Wrench Fetcher Joined: May 2016 Posts: 42 | As always! So what about the data plate inside on the kick panel? It looks like it has the same big rivets holding it in as others I've seen online. Possibly they replaced the kick panel just so that it matched the VIN tag. I'm not going to worry about all of it too much seeing as the DMV titled and licensed it already. I'm not planning on selling it and I'm not planning on entering it into any shows or contests. I'd rather not have to change anything on it if I don't have to. I'm going to try crawling in and under it again to see if I can find a partial VIN on the frame when I get time. Maybe I can find something.
| | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | You have the info you needed, some of it is unknowable, but you have been advised about the "inconsistencies" and theories on how it all happened. You are not selling, it went thru DMV. You may or may not clone it further, up to you. Others, including me, have seen and owned trucks like this. We hope someone does not come along and seize them. Probably not. I really hate this phrase BUT: "it is what it is".
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Mar 2009 Posts: 788 'Bolter | | 'Bolter Joined: Mar 2009 Posts: 788 | nbrs on the outside of the frame were usually part nbrs. there should be a # also on the other rail which may be one digit difference. a chev frame will have tge ser # embedded on the top of the frame by the steering box which should corespond to which is on the Vin plate; just the last 5 or 6 digits. GMC will not have it on the frame. tnere is not much difference between a chev and gmc frame once someone puts a xbc in it. the exception is the rear suspension. GMC have semi- elliptic springs and Chev have coils, there has been a lot of juggling around with bodies and vin plates over the years ansd most do not seem to care of the legal part of it. the onus will always fall on you if something goes cow poop. if you are ever in a serious accident with it and no one is ever invincible. that is when things get inspected thourougly and things don't match you may have to have pretty deep pockets as insurance companies always like a way out out and if registration is not correct their gone. the old story: it will never happen to me. accidents are always happening to someone ron | | | | | Joined: May 2016 Posts: 42 Wrench Fetcher | | Wrench Fetcher Joined: May 2016 Posts: 42 | Well I certainly appreciate you guys' input on it. I have a lot to learn about the truck and you've definitely given me a lot to work with. All-in-all I just have to be happy that I have the truck and can enjoy it, mystery included.
