9 members (GMCJammer51, Materman, Lightholder's Dad, Ridgeback, Brian Moore, tclederman, jupitor, treegrower, 1 invisible), 189 guests, and 2 robots.
Topics128,080
Posts1,055,952
Members48,430
#1169830 06/17/2016 2:55 AM
Headlights go off almost immediately after their turned on. I also hear a click noise when it happens
thrs50 #1169839 06/17/2016 3:23 AM
You have a short which is tripping the circuit breaker in the light switch. After a few seconds, the breaker will reset itself and flash the lights momentarily if you leave the switch turned on. Check the dimmer switch- - - -it's been a chronic source of short circuits for the 50-something years I've been doing electrical work.
thrs50 #1169840 06/17/2016 3:23 AM
what vehicle
Redryder pix
My Hotrod
thrs50 #1169841 06/17/2016 3:29 AM
1952 3100
When the high beams are on lights work when they're off lights click off so is this a good indication that I need to replace the high beam switch
thrs50 #1170019 06/18/2016 1:29 AM
Also check for a shorted wire between the dimmer switch and the high beam wiring to the lights.
Wiring is OK
thrs50 #1170783 06/23/2016 3:29 AM
remove the headlights then try the switch. If it still trips,,you have a wiring issue
thrs50 #1170809 06/23/2016 5:25 AM
Sir Searchalot
Sir Searchalot
Can't you just reverse the wiring on the dimmer terminals and see if the low beam stays on and hi goes off? or continuity test or test light test.
