7 members (Charles in CA, Otto Skorzeny, Lonnie, 1955 1 Series, dt235sd, Wickedbass, 1 invisible),
125
Mod | | | Forums66 Topics128,081 Posts1,056,076 Members48,434 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2014 Posts: 41 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2014 Posts: 41 | I'm still trying to find decent tie rod ends that are not wobbled out. So I had this idea. Isn't the part that attaches to the back side of the spindle the same shape and attachment point on a 1/2 ton and 3/4 ton. So why not swap parts to a 1/2 ton type and use new style tie rod ends? Not going to haul anything any way. Ideas?
Thanks | | | | | Joined: Feb 2000 Posts: 5,215 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,215 | Not real sure what part you are looking for, is it the ball ends or the socket ends? Here you will find tie rod repair kits and replacement tie rods for 1932 to 1959 trucks, 1/2 to 3/4 ton, https://www.chevsofthe40s.com/dept/Steering/cat/Tie+Rods.htmlJoe
| | | | | Joined: Jun 2014 Posts: 41 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2014 Posts: 41 | I can get the ball ends locally at Jim Carter's. I need the socket ends. The tie rods ends listed won't fit the 3/4 because the 3/4 requires a tapered stud at least that is what came out. If there is a way I'm up for it.
Thanks | | | | | Joined: Feb 2000 Posts: 5,215 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,215 | All of the older trucks use a straight shaft ball end. Yours may look tapered, but I bet they are not and any of the kits will work. If it like a modern piece with a true taper, someone has messed. | | | | | Joined: Jun 2014 Posts: 41 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2014 Posts: 41 | Ok. I will measure studs. Hopefully they will fit.
Thanks | | | | | Joined: Jun 2013 Posts: 19 New Guy | | New Guy Joined: Jun 2013 Posts: 19 | Hello! have you had a chance to change the tie rod ends, I've been wanting to do the same, changing to a half ton axle is what I'm considering doing myself, the 1/2 ton and 3/4 ton measure the same. | | | | | Joined: Jun 2014 Posts: 41 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2014 Posts: 41 | I talked to a guy at Jim Carter's and he seemed to think it would work. Apparently had never thought of it before. Just need to find the parts from a half ton. | | | | | Joined: Jun 2003 Posts: 565 'Bolter | | 'Bolter Joined: Jun 2003 Posts: 565 | 1/2 ton studs are straight, my 1957 3/4 ton had tapered studs. I don't know about your year.
"Do not walk behind me, for I may not lead. Do not walk ahead of me, for I may not follow. Do not walk beside me either. Just leave me alone, you're starting to freak me out."
1957 GMC 150
| | | | | Joined: Jun 2014 Posts: 41 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2014 Posts: 41 | My '49 3/4 ton does have tapered studs. The drag link studs are not tapered but both are different sizes. One is 5/8 and the other 3/4. I ordered from the Filling Station as they were the only place I could find them. | | |
