3 members (Gdads51, Bill Hanlon, Otto Skorzeny), 65 guests, and 0 robots.
Topics128,080
Posts1,055,951
Members48,430
#1169572 06/15/2016 5:37 PM
Hi All,
So I am in the process of a 12V conversion and have a 10SI alternator, but would like to keep some original appearance with the correct Voltage Regulator on the firewall. Has anyone rigged the original VR as a junction box or "Dummy", and if so, how?
Thanks for your help!!!!
Take the cover off and look where the connections are between the 3 external terminals and start cutting all of the coil wires from the terminals and start bridging the terminals together until you have what you want. Pretty easy to figure out once you git the lid offen the pickle barrel, as they say.
Carl
retty
Sir Searchalot
Sir Searchalot
Why would you want to retain the VR look when everyone sees the Alt? Anyone who would know what the correct VR is would be impressed but also be unimpressed with the alternator. Do you have the alt that looks like a generator? Mount it up and hide an extra ignition key in it. chug
Gas Pumper
Gas Pumper
Lots of ways to use that box. Here is another one..
http://talk.classicparts.com/threads/deves-hei-kit-with-help-from-bilbo.22233/
Myself, I am happy with the extra space on the firewall. If you take Bart's advice, don't tell anybody!
Deve
1950 Chevy 3100 Deluxe Cab
1950 Chevy 3100 Standard Cab
The Think Tank
[url=]Perfect place for a fuse block! [/url]
1948 5-window 3100 Chevy
327 V-8 TBI 700R4 Posi 3.73
"Old Blue"
More pix on Flickr
"Old Blue"
More pix on Flickr
I've got my fuel pump relay in there also.
"Old Blue"
More pix on Flickr
Originally Posted by Flatblu4748
I am not restomod guy, but that looks nice. Great reuse.
Lots more pictures
If you clean up and paint the alternator black, it doesn't stick out like a sore thumb. It also sits low on the engine, pretty much unnoticeable, especially being black in color. The absence of the voltage regulator would stand out IMHO.
carl
I saw truck at show that had button switch on the regulator box. A bolt on the hood held the button down with the hood closed. When the hood was opened the radio antenna retracted so it wouldn't interfere with the hood.
Sir Searchalot
Sir Searchalot
Oh, now I know what AD stands for.
Blumarin, I left the voltage regulator as a dummy when I installed a 10SI alternator. I needed to install an alternator when I added A/C. I used the BAT terminal on the voltage regulator as a junction terminal for the battery connections and just don't have any wires connected to the other two terminals.
If you install a three wire alternator, this will give you a great place to attach the voltage sensing wire if you hook it up the way I did. My A/C power feed also is attached to this terminal.
Matt
I found this picture that shows how it looks.
The white wire that you see connected to the ignition resistor is the exciter wire from the alternator that needs the diode soldered to it.
The BAT wire and the sensing wire from the alternator are both attached to the BAT terminal of the dummy voltage regulator.
http://s844.photobucket.com/user/ma...2981_zps673417ae.jpg.html?sort=3&o=3
Matt
