2 members (N-man, 3800GUY), 126 guests, and 1 robot.
Topics128,131
Posts1,056,724
Members48,454
#1169264 06/13/2016 6:07 PM
After replacing the clutch pedal bushing, I noticed the wear in this eyebolt that the pedal connects to. Is this the correct part, or something that was used by a previous owner because it worked? The eyebolt has a good 1/8 th inch notch in it, and I'd like to replace or repair it. Just thinking the easiest thing to do is run to the hardware store and pick up another one like it.
1938 Chevy 1/2-ton
More info in the Gallery Forum
She looks good at 50 yards, and 35 miles per hour, on a dark night.
Crusing in the Passing Lane
This is reasonably common. Could get a new one, or just bush it with an oilite bushing from your hardware store or make one on your lathe.
Ed
That is the correct link bolt.
I would just weld up the wear area.
My Blog
Hoff #1169483 06/15/2016 12:14 AM
Thanks. I tried to find a replacement and while some were close, they were not bent quite as tight. I'll go with a weld repair.
1938 Chevy 1/2-ton
