5 members (Otto Skorzeny, Shardean, 3B, 55shaker, rick46ia), 83 guests, and 2 robots.
Topics128,023
Posts1,055,365
Members48,420
#1169367 06/14/2016 9:25 AM
I have a 1953 Chevy truck with a 235 is it better to use a 6v starter ot a 12v starter . I converted the electrical to 12v ... I know they sell 12 v starters .
sal moreno #1169396 06/14/2016 2:31 PM
Redryder pix
My Hotrod
sal moreno #1169452 06/14/2016 8:43 PM
The starter needs to be matched to the flywheel. 6 Volt starter works fine on a 12 Volt system( foot start). A solenoid starter is a different beast. 6 Volt starter with a 6 Volt flywheel. 12 Volt starter with a 12 Volt wheel. The diameter and tooth pitch are different(count the teeth on the flywheel to determine what you have). 139 teeth on the 6 Volt fly wheel. More on the 12 Volt one.
Steve H
sal moreno #1169460 06/14/2016 9:27 PM
Steve, fyi, the link Bob's your uncle told him that
also.
Redryder pix
My Hotrod
sal moreno #1169514 06/15/2016 4:00 AM
One of the reasons that I reluctantly abandoned the six volt starter was the incredible increase in RPM that the 12 volt battery turns the six volt starter. Instant start up without the "I think I can, I think I can" sinking feeling of the six volt battery. Having said that, the other reason I made the switch was the frustration that I had with the voltage regulator (I went with a one wire, internal regulator alternator).
Carl
