4 members (59 fleet, 3800GUY, Charles in CA, IHPWR), 144 guests, and 4 robots.
Topics128,107
Posts1,056,225
Members48,436
#1169351 06/14/2016 4:51 AM
Hi everyone. I am having trouble removing the oil pump. I can't seem to get the bolt holding the pump in off. It wouldn't budge and I didn't want to break the head off. Is there anything special that I need to do to get this bolt off or any suggestions?
Crusing in the Passing Lane
Gentle heat will solve most issues.
Ed
Have you loosened the lock nut?
My Blog
What does the lock nut look like/where is it?
I am going to assume you must be trying to remove the pump by removing the two bolts with round heads on the outside of the engine. DO NOT DO THAT!
The bolt that holds the pump in is on the inside of the engine. It takes a 1/2" wrench, and has a lock nut on it tightened against the block to prevent it from loosening. The lock nut takes a 9/16" wrench.
Sorry, I could not easily come up with a picture.
I am assuming you are asking about a 1937-62 engine.
My Blog
I was trying to remove the lock nut and bolt but I was being too gentle. I have it off now but the pump will not come out. I loosened the nuts on the pipes and those are loose but the pump still won't come out.
Tap the sides of he pump with a hammer to break the junk loose.
Use a rubber or leather mallet if you have one..
1959 3100 Apache Fleetside
A slight twisting and pulling has worked for me.
My Blog
