0 members (),
61
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,049 Posts1,055,743 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2015 Posts: 60 Shop Shark | | Shop Shark Joined: Aug 2015 Posts: 60 | Would someone please share which post s the field post, and which is the armature, n the generator? Also confirm the voltage regulator ? The wiring diagram is not clear.
Steve
'46 Chevrolet 1/2 T. Pickup, survivor - sold '31 Ford Model A pickup
| | | | | Joined: Oct 2002 Posts: 4,066 Bolter | | Bolter Joined: Oct 2002 Posts: 4,066 | see if this tech tip helps you might also check the tech tip section to see if they may help, are you asking about your 46 chevy?
Redryder pixMy HotrodA veteran - whether active duty, retired, national guard, or reserve - is someone who, at one point in his or her life, wrote a blank check made payable to The 'United States of America', for an amount of "up to and including my life."I am fighting cancer and I am winning the fight | Pain is part of life; misery is an option. | | | | | Joined: Apr 2004 Posts: 5,072 Authorized Pest | | Authorized Pest Joined: Apr 2004 Posts: 5,072 | And if you have any questions, Hotrod Lincoln is the fellow who wrote the Tech Tip.
~ Peggy M 1949 Chevrolet 3804"Charlie" - The Stovebolt FlagshipIn the Gallery"We make a living by what we get; we make a life by what we give." -- Winston Churchill | | | | | Joined: Feb 2004 Posts: 29,771 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,771 | Does your generator have a spring steel band around the housing on the opposite end from the pulley, or is the housing solid? If it's got the band, remove it and look for the terminal post that is connected to one of the brushes with a flexible pigtail wire. That one is the Armature lead. The same information can be learned by removing the rear plate of the solid-housing generator, but be careful that the pieces don't fall apart- - -the through-bolts hold both ends on. Jerry
| | | | | Joined: Aug 2015 Posts: 60 Shop Shark | | Shop Shark Joined: Aug 2015 Posts: 60 | This is a Delco-Remy generator, stock, with two post n the back. What I need to know is the outboard, or driver's side, the field or armature post. I need to connect the proper post correctly to he voltage reg.
Steve
Steve
| | | | | Joined: Jul 2008 Posts: 1,321 'Bolter | | 'Bolter Joined: Jul 2008 Posts: 1,321 | Steve, I believe Jerry answered this question in his post above. Only you know if your has a band on it or is solid. Harold
Harold Is a restoration ever finished? | | | | | Joined: May 2005 Posts: 1,624 Shop Shark | | Shop Shark Joined: May 2005 Posts: 1,624 | Guys, I think he is saying he has a non adjustable output generator and just needs to know which wires go where from the two posts to the regulator.
| | | | | Joined: Feb 2004 Posts: 29,771 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,771 | It's possible to reverse the connections inside the generator housing during a rebuild. the only surefire way to tell which way to connect the wiring is to:
LOOK AT THE BRUSH WIRING like I suggested!
Since the only person who can do that is our new guy, any more discussion is moot. I've seen these generators set up both ways! Jerry
| | | | | Joined: Nov 2007 Posts: 190 Shop Shark | | Shop Shark Joined: Nov 2007 Posts: 190 | The generator case will have a "F" stamped into the housing under one post. This is the Field terminal and will go to your "F" or Fld. terminal on the regulator. The other terminal on the generator will have a "A" stamped in the case under the terminal. This is the armature terminal and it will go to the "ARM" terminal on the regulator. Ken | | | | | Joined: Aug 2015 Posts: 60 Shop Shark | | Shop Shark Joined: Aug 2015 Posts: 60 | Thanks, Ken. That's is close to what I was looking for. I was hoping it was as simple as...."the outboard post is the xxxx".
Steve
Steve
