4 members (Charles in CA, Otto Skorzeny, 2 invisible), 107 guests, and 2 robots.
Topics128,081
Posts1,056,076
Members48,434
#1169341 06/14/2016 4:10 AM
Z
Z Offline
Hi...my 1953 1/2 ton Chevy truck has only one horn on the left (driver) side and it sounds like a high pitched VW.
Did all 1953 1/2 ton trucks have one horn or two horns ?????
Thanks in advance......J
1953 chevy 1/2 ton with 3 speed 318 on floor and 1955 235 engine
1953 trucks came with a standard single horn attached to the forward part of the intake manifold. It was a "sea shell" style horn. That year also used a firewall mounted relay with the horn.
A set of high tone and low tone sea-shell style horns was an option/accessory.
Z
Z Offline
Thanks Tim...This is just the info I was looking for.
My single horn is a sea-shell style and in the place you stated...I just think the horn sounded too girlish for such a manly looking truck. :} J
5 Online: Content
I had a 66 Buick with dual high-low horns. It was music to the ears! I always look for those when I hit the older junkyards. They look similar to the 53 and later seashells.
One of the few options my '46 came with when new was the twin horns on the firewall. When I rewired it years ago all the horn connections were factory. Does sound better than the less-than-robust factory single horn.
I'm using the factory dual horns on my '46. When you put 6V horns on 12V, they sure are loud.
My 46 GMC on Photobucket
