0 members (),
344
Mod | | | Forums66 Topics128,162 Posts1,057,042 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2014 Posts: 128 Shop Shark | | Shop Shark Joined: Jun 2014 Posts: 128 | Here is an easy one for you. Do I have to drain the differential before I remove the axle shaft?
Sometimes you're the window Sometimes you're the bug
| | | | | Joined: Apr 2015 Posts: 336 Shop Shark | | Shop Shark Joined: Apr 2015 Posts: 336 | If there isn't a drain plug, put speedy dry (kitty litter) or a catch pan under the axle end to catch the oil that will come out.
1959 3100 Apache Fleetside
| | | | | Joined: Nov 2011 Posts: 1,611 'Bolter | | 'Bolter Joined: Nov 2011 Posts: 1,611 | A small amount of oil will leak out. Park with the axle in need of repair up-hill (or jack stand) and no leaks. | | | | | Joined: Jun 2014 Posts: 128 Shop Shark | | Shop Shark Joined: Jun 2014 Posts: 128 | Thank you, Saved some spill space on my driveway for brake fliud
