2 members (78buckshot, 1 invisible), 390 guests, and 5 robots.
Topics128,162
Posts1,057,042
Members48,463
Here is an easy one for you. Do I have to drain the differential before I remove the axle shaft?
Sometimes you're the window
Sometimes you're the bug
If there isn't a drain plug, put speedy dry (kitty litter) or a catch pan under the axle end to catch the oil that will come out.
1959 3100 Apache Fleetside
A small amount of oil will leak out. Park with the axle in need of repair up-hill (or jack stand) and no leaks.
Lots more pictures
Thank you, Saved some spill space on my driveway for brake fliud smile
