2 members (dinosoar, 52Carl),
82
Mod | | | Forums66 Topics128,127 Posts1,056,677 Members48,452 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2014 Posts: 77 Shop Shark | | Shop Shark Joined: Sep 2014 Posts: 77 | I have restored a 1950 1300 Chevrolet 5 window back to factory built condition. It has one left tail light for running and brake. I am considering putting turn signals onto it. Did these trucks have that option available ? Does anyone know where I can see pics of the parts that I'll need to do the install? Thanks John. | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | John,
There was no factory-option turn signals in 1950, but there were GM accessory turn-signal switches/lamps (very rare).
Parts vendors sell right rear lamps and hangers. Some vendors sell turn-signal switches (look in "Links"). The can be used with 6v or 12v bulbs.
| | | | | Joined: Nov 2008 Posts: 465 'Bolter | | 'Bolter Joined: Nov 2008 Posts: 465 | John,
Parts vendors sell right rear lamps and hangers. Some vendors sell turn-signal switches (look in "Links"). The can be used with 6v or 12v bulbs. what have members done for dash indicators for turn signals? Also, FAM shows a ignition switch bulb in the igniton bracket,but that is behind the dash,what does it light ? | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | The ignition switch bulb dimly lights the ignition switch.
In 1954, there was one signal indicator light - at middle bottom of the speedometer gauge. | | | | | Joined: Sep 2014 Posts: 77 Shop Shark | | Shop Shark Joined: Sep 2014 Posts: 77 | Great info. Thanks to all. John. | | | | | Joined: Mar 2007 Posts: 4,215 Moderator | | Moderator Joined: Mar 2007 Posts: 4,215 |
what have members done for dash indicators for turn signals? [/quote]
My signal-stat 900 has indicator lights on the unit. | | |
