2 members (Cosmo, Wayne67vert), 43 guests, and 2 robots.
Topics128,089
Posts1,056,004
Members48,430
#1168992 06/11/2016 6:42 PM
Has anyone had experience not using a booster on their master cylinder? Do you have to have a heavy foot?
Im installing disc brakes on the front of my 53 1300 and installing a dual reservoir cylinder so wondered about the need for a booster.
I vote for a vacuum booster. They make booster/dual master cyls that bolt into the stock location. That is what I used on my 51 one ton disc brake conversion and the brakes are GREAT!
Why would you not want to use a booster? If I remember correctly, disc brakes use a larger piston in the master cylinder than manual brakes. I believe something like 1-1/8" vs 7/8". This would require a very heavy foot indeed.
One thing you have to remember, disk brakes are not self energizing like the Bendix style drum brakes your truck comes with. That will lead to more pedal effort without a booster. Small, lightweight cars, like early style hot rods and small sports cars can get away with it better that heavier cars and trucks. Even with the manual brake specific master cylinder, the pedal effort is much higher than it is for manual drums. Best bet is if you're going to swap to disk, go ahead and do the power conversion as well. There's plenty of vacuum boosters on the market for a stock location mounting.
Bill Burmeister
