| | | Forums66 Topics128,281 Posts1,058,472 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2005 Posts: 38 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2005 Posts: 38 | I wish I could put a picture out- but no digital camera or scanner. I'll try to describe...I have 2 trucks, one is a '48 for sure, the other is either '47 or '48, same exact style truck, but a lower serial number. Every picture I have seen of original trucks have the upper portion of the sides being round. BOTH of my trucks are square, and one I am 98% certain is original. So, what gives? Any ideas? Were these produced in Canada with different boxes? Do the long beds have a different style than the short beds? Was there a common aftermarket box put on back then on new trucks ordered without them? Both of them being the same, but different than any others I've seen is just weird. One is from Wisconsin, one is from Minnesota. I know one of them had the original wood bottom at one point, I talked to the guy that took it out. I'll try to borrow a camera and get pictures out. | | | | | Joined: Feb 2000 Posts: 988 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 988 | JaNeily the bed sides of the 47 and 48 should come straight up off the bed and then bend (out) at an aprox 45 degree angle and then roll over into a tube. In the early 50's (53 I think) the bed sides change to bending at a 90 degree angle and then rolling into a tube. Hope this helps if not go look at the gallery and see if you can find something like what you have.
Brian Moore 1949 3100 5 window Deluxe "Today is better than yesterday, but not as good as tomorrow" | | | | | Joined: Jun 2000 Posts: 454 Shop Shark | | Shop Shark Joined: Jun 2000 Posts: 454 | Originally posted by Brian Moore: In the early 50's (53 I think) the bed sides change to bending at a 90 degree angle and then rolling into a tube. This change occurred with the 1954 model year, not the 53.
Jeff Nelson
"Beer is proof that God loves us and wants us to be happy." - Benjamin Franklin "Always do right. This will gratify some people and astonish the rest." - Mark Twain
| | | | | Joined: Feb 2005 Posts: 355 Member | | Member Joined: Feb 2005 Posts: 355 | Yep, Jeff's right. The change to a 90 degree bend with flat bed rails happened in '54. | | | | | Joined: Jun 2005 Posts: 38 Wrench Fetcher | | Wrench Fetcher Joined: Jun 2005 Posts: 38 | But they all roll over into a tube is what I'm hearing. Both of mine are '48's, which I figured out today from another site. They both come out at the 45 deg angle, then come down at a square 90 deg, then another 90 deg, and a third, so it's basically square where the tube should be. I just find it interesting that they both are almost identical, except for a 6" length difference, and not a tube. They also only have 2 stantions (spelling?) instead of 3. I am in a debate with my wife, who swears the box on the truck from Minnesota is original. I know better, but I must be wrong, after all, I'm alone in the woods.... I borrowed a camera from work and got some pictures taken, but have no software to download to my computer. I'll work on that one next. Thanks for the help! | | | | | | Anonymous Unregistered | | Anonymous Unregistered | hmm thats interesting, I have never (as I can recall) seen a box with no rolls, but a square... | | | | | Joined: Feb 2000 Posts: 988 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 988 | My guess is that they were aftermarket boxes or homemade..... you might look throught the gallery (with your wife ) and see if you can find a square tube bedside. My guess is that there isn't a one. Good luck.
Brian Moore 1949 3100 5 window Deluxe "Today is better than yesterday, but not as good as tomorrow" | | | | | Joined: Oct 2004 Posts: 1,780 Master Gabster | | Master Gabster Joined: Oct 2004 Posts: 1,780 | This should answer your question on if you have an original bed...g 54 box 1940 bed 1946/7 bed 1948 bed | | |
