| | | Forums66 Topics128,052 Posts1,055,740 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2014 Posts: 307 'Bolter | | 'Bolter Joined: Aug 2014 Posts: 307 | Any recommendation for a paint stripper? Particularly for the door trims. Tried Goof off and lacquer thinner without much success. Thanks, Scott | | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | What year? Original paint?
I buy the most expensive, strongest, paint remover at Home Depot.
Use it outside, if you can - do not breathe the fumes and do not get it on your skin - oh yeah, it will probably eventually destroy any type of protective gloves. | | | | | Joined: Aug 2005 Posts: 442 'Bolter | | 'Bolter Joined: Aug 2005 Posts: 442 | I used Citrus stripper, available at H Depot, Walmart etc.. It's orange in color, environmentally safe and not obnoxious fumes. I used it stripping off 4 coats of paint. Mike | | | | | Joined: Nov 2010 Posts: 430 'Bolter | | 'Bolter Joined: Nov 2010 Posts: 430 | Scott, Be very careful not to get paint stripper in any seems. You will never get it out and it will continue to strip the paint off for many years to come. Most of the time I use 80 grit DA to remove paint. If it's something large like a hood I may use paint stripper, but I stay away from the edges by a couple inches and sand that portion off. The last thing you want after new paint is for it to bubble up due to the paint stripper.
Good luck. | | | | | Joined: Dec 2000 Posts: 3,399 Gas Pumper | | Gas Pumper Joined: Dec 2000 Posts: 3,399 | As long as you are going to sandblast it next, or completely clean it everywhere first, paint stripper is an option. There is no way I would use it on anything that has a seam unless you can take it apart. The best paint stripper is Arm-Strong. | | | | | Joined: Jun 2016 Posts: 236 DLBrooks | | DLBrooks Joined: Jun 2016 Posts: 236 | sandblast it and forget the stripper | | |
