7 members (Otto Skorzeny, Wayne67vert, 1955 1 Series, Chris's 46 / 515, KEVINSKI, JoergK., WICruiser),
103
Mod | | | Forums66 Topics128,172 Posts1,057,109 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2012 Posts: 142 Shop Shark | | Shop Shark Joined: Jun 2012 Posts: 142 | Anyone have the demensions of the wood that supports the body to the frame.for a 42 suburban.any and all help is appreciated | | | | | Joined: Jun 2005 Posts: 96 'Bolter | | 'Bolter Joined: Jun 2005 Posts: 96 | They are available as a kit from Jim Carter.
Richard J Patrick - 1946 Suburban
| | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | What is the JC part number for the blocks for a 1942 Suburban? I cannot find the blocks specifically listed for 47-55 Suburbans (but, JCs search system is a challenge). The blocks might be in this kit: 47-55 kit of fasteners and rubber parts that attach cab to frame | | | | | Joined: Jun 2012 Posts: 142 Shop Shark | | Shop Shark Joined: Jun 2012 Posts: 142 | I know that someone manufacturers them,I was just looking to see if anyone knew the actual height and length.thanks for all the help fellas. | | | | | Joined: Jun 2005 Posts: 96 'Bolter | | 'Bolter Joined: Jun 2005 Posts: 96 | There are several different ones of varied shapes and sizes. I sent an original set to Jim Carter and they reproduced them. Call and ask, they may share the info you seek.
| | | | | Joined: Jun 2012 Posts: 142 Shop Shark | | Shop Shark Joined: Jun 2012 Posts: 142 | | | |
