3 members (jay d, 2 invisible),
54
Mod | | | Forums66 Topics128,009 Posts1,055,292 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2007 Posts: 46 Wrench Fetcher | | Wrench Fetcher Joined: Feb 2007 Posts: 46 | In my 48 Chevy i/2 ton I have installed a mustang two front suspension and am trying to decide on what engine to run, I have a 305 that needs a refreshing or rebuild. My other option is to buy a crate motor such as a new gm 350 for around 1500 from summit racing. I had also considered trying to find a good used 4.3 and convert it to carb but this seems a little pricey. Any help will be appreciated thanks, Barry | | | | | Joined: Apr 2015 Posts: 336 Shop Shark | | Shop Shark Joined: Apr 2015 Posts: 336 | I like the 283 and 327's myself.
1959 3100 Apache Fleetside
| | | | | Joined: Mar 2005 Posts: 1,636 'Bolter | | 'Bolter Joined: Mar 2005 Posts: 1,636 | The 305 you have can be made into a sweet engine. I've had several over the years and they served me well. |
I like the 283 and 327 as well, if you can get one reasonable.
| | | | | Joined: Apr 2005 Posts: 2,097 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,097 | I have installed several GM crate engines and have had success with them. Keep in mind that you still need to obtain intake & exhaust manifolds, carburetor, distributor, water pump, pulleys, flywheel, and other accessories which may cost another $800 to $1000. If you can find a complete running small block that may be the way to go. I have found in some cases that the cost of buying a used engine and having it rebuilt can cost as much or more than getting a crate engine and the related components. Fred
| | | | | Joined: Jun 2004 Posts: 8,597 Riding in the Passing Lane | | Riding in the Passing Lane Joined: Jun 2004 Posts: 8,597 | I would buy the 350 crate engine & use the parts & assec. off the 305. They say money can't buy happiness. It can buy old Chevy trucks though. Same thing. 1972 Chevy c10 Cheyenne SuperIn the Gallery Forum | | | | | Joined: May 2005 Posts: 8,983 Sir Searchalot | | Sir Searchalot Joined: May 2005 Posts: 8,983 | Do not waste money on a 305. Not a bad engine for it's day. Built for economy during the new smog requirements. Most parts will fit a 350. Especially external.(same stroke also) It is not very powerful compared to what a 350 can do with minimal "speed equipment". They are, however, very cheap to buy. Short block 350 crate with your 305 parts is probably a good idea, as WBender.Ret said. Get into the 4" bore world.  Makes no sense for you to build smaller that 350 except nostalgia/correctness. Cubic inches is as cubic inches does.
Right is right, even if everyone is against it, and wrong is wrong, even if everyone is for it. - William Penn | | | | | Joined: Mar 2008 Posts: 1,775 'Bolter | | 'Bolter Joined: Mar 2008 Posts: 1,775 | Vortec 4200 from a Trailblazer/Envoy. 300 hp. Overdrive trans. You can probably buy a running donor vehicle with everything you need for about the same money as a new small block. | | |
