1 members (Danielbolt), 164 guests, and 3 robots.
Topics128,149
Posts1,056,818
Members48,456
#1168347 06/06/2016 2:28 AM
In my 48 Chevy i/2 ton I have installed a mustang two front suspension and am trying to decide on what engine to run, I have a 305 that needs a refreshing or rebuild. My other option is to buy a crate motor such as a new gm 350 for around 1500 from summit racing. I had also considered trying to find a good used 4.3 and convert it to carb but this seems a little pricey. Any help will be appreciated thanks, Barry
I like the 283 and 327's myself.
1959 3100 Apache Fleetside
The 305 you have can be made into a sweet engine. I've had several over the years and they served me well. |
I like the 283 and 327 as well, if you can get one reasonable.
I have installed several GM crate engines and have had success with them. Keep in mind that you still need to obtain intake & exhaust manifolds, carburetor, distributor, water pump, pulleys, flywheel, and other accessories which may cost another $800 to $1000. If you can find a complete running small block that may be the way to go. I have found in some cases that the cost of buying a used engine and having it rebuilt can cost as much or more than getting a crate engine and the related components.
Fred
Riding in the Passing Lane
I would buy the 350 crate engine & use the parts & assec. off the 305.
1972 Chevy c10 Cheyenne Super
Sir Searchalot
Sir Searchalot
Do not waste money on a 305. Not a bad engine for it's day. Built for economy during the new smog requirements. Most parts will fit a 350. Especially external.(same stroke also) It is not very powerful compared to what a 350 can do with minimal "speed equipment". They are, however, very cheap to buy. Short block 350 crate with your 305 parts is probably a good idea, as WBender.Ret said. Get into the 4" bore world. grin Makes no sense for you to build smaller that 350 except nostalgia/correctness. Cubic inches is as cubic inches does.
Vortec 4200 from a Trailblazer/Envoy. 300 hp. Overdrive trans. You can probably buy a running donor vehicle with everything you need for about the same money as a new small block.
1954 3600 Chevy Truck
"The Fake Truck"
More pix on Photobucket
