0 members (), 77 guests, and 1 robot.
Topics128,030
Posts1,055,428
Members48,422
#1168297 06/05/2016 8:29 PM
Z
Z Offline
When adjusting rear brakes on a 53 1/2 ton truck, which rear brakes are adjusted first, parking or rear brake shoes ? thank you....J
1953 chevy 1/2 ton with 3 speed 318 on floor and 1955 235 engine
1 Offline
always adjust the brake shoes first. Years ago when the park brake wouldn't hold, or felt like it need to be adjusted, adjusting the brake shoes back to where the should be, made the park brake hold ok without adjusting.
Joe
The older I get, I only want to work on older rigs.
You need to back off the parking brake adjustment all the way prior to adjusting the brake shoes. If you don't, the parking brake parts could interfere with the shoe adjustment. After the shoes have been adjusted, you can then adjust the parking brake.
Carl
Z
Z Offline
Thank you Joe & Carl.....
