6 members (Peggy M, NJC, Forty9, Donf, FAST55, 1 invisible), 69 guests, and 2 robots.
Topics128,023
Posts1,055,367
Members48,420
#1168324 06/06/2016 1:11 AM
Hello all, I own a 1936 Chevy pu, however this is a problem with my other car; It is a 1973 Buick 455 motor & it started missing & then died & will not restart; I have power thru the resister & both posts on the coil but nothing to the distributor; Thinking the wire from the coil to the dist. was bad I replaced it to no avail. I connect a jumper direct from battery to distributor & it burns the wire into. I then took dist. apart & insulator & all looks good. Near as I can tell, the dist. is shorting out. Anyone have any ideas? All help is greatly appreciated. Richard.
Condenser developed a short. Is my first guess.
Thx for the reply, I'll replace the condenser & see if thats the problem.
