| | | Forums66 Topics128,115 Posts1,056,623 Members48,450 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2015 Posts: 56 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2015 Posts: 56 | HI all,
Besides my recent post on my shifting problems with a new clutch a few minutes ago, I also experienced what appears to be a water pump failure on my last drive. I parked it to get gas and she lost a significant amount of coolant. I looked under the hood and traced it down to apparently coming from the bottom of the water pump ( weeping hole?)
I have a friend mechanic who told me that most pumps of this era had a way to blow out excessive pressure so things like bearing failure, etc. in the pump did not send things into the block. The question I have is that the pump appeared to be quite new and I am wondering where else I might want to look for root cause of the problem. I have not had any overheating issues, and the temp gauge does work - it starts cold and ends up in the middle ( although I understand it does not prove it is working ) - I have not had any coolant exit via the overflow tube and I checked the coolant a week before and it appeared very clean and up to the cap when cold and in my garage. Besides buying a new pump, I have also bought a new thermostat ( 160 degree ) with the little hole in the thermostat, per my friends suggestion to allow trapped air out - I am wondering now what else might have caused this. Although I am not pleased having to buy a new water pump, I will be quite relieved if this is the problem, instead of a clogged block, etc. - thoughts? - I should add it is a 55 first series 3100, 235 and I drive it locally for pleasure only about 1 hour at a time - no towing or anything above about 50MPH. Yesterday when the pump went out it was the hottest day I have driven it so far with temps in the low 80's
Since I have the courage to tackle replacing a water pump, and thermostat - does anyone have some words of wisdom to look for in case the failing pump is symptomatic of something else I should be looking for?
thanks
Joe
Joe Finkelstine Born and bred in Motown
| | | | | Joined: Mar 2010 Posts: 10,294 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,294 | The leak is caused by a worn out bearing. Once the shaft starts wobbling, the seal can no longer do its job. Try to avoid over-tightening the fan belt, as this can significantly shorten the life expectancy of water pump bearing, as well as those in the generator/alternator. Carl
| | | | | Joined: Dec 2015 Posts: 56 Wrench Fetcher | | Wrench Fetcher Joined: Dec 2015 Posts: 56 | Hi Carl Thanks for the suggestion. I used to check tension by measuring deflection at mid point - I am wondering if this is still good and how much deflection I should see - stock motor with no power accessories
Thanks for your response - I hope to replace the pump tomorow
| | | | | Joined: Jun 2005 Posts: 481 'Bolter | | 'Bolter Joined: Jun 2005 Posts: 481 | 52Carl,
Do you know how tight (what torque)the fan bolts should be?
John | | | | | Joined: Sep 2001 Posts: 29,270 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,270 | | | | | | Joined: Apr 2008 Posts: 899 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 899 | Shop manual (47-51) pg 6-39 shows deflection as you measure to be 3/4" at midpoint.
Ed
