| | | Forums66 Topics128,021 Posts1,055,351 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2007 Posts: 48 'Bolter | | 'Bolter Joined: Apr 2007 Posts: 48 | Hello all, I own a 1936 Chevy pu, however this is a problem with my other car; It is a 1973 Buick 455 motor & it started missing & then died & will not restart; I have power thru the resister & both posts on the coil but nothing to the distributor; Thinking the wire from the coil to the dist. was bad I replaced it to no avail. I connect a jumper direct from battery to distributor & it burns the wire into. I then took dist. apart & insulator & all looks good. Near as I can tell, the dist. is shorting out. Anyone have any ideas? All help is greatly appreciated. Richard. | | | | | Joined: Jan 2015 Posts: 914 'Bolter | | 'Bolter Joined: Jan 2015 Posts: 914 | Condenser developed a short. Is my first guess. | | | | | Joined: Apr 2007 Posts: 48 'Bolter | | 'Bolter Joined: Apr 2007 Posts: 48 | Thx for the reply, I'll replace the condenser & see if thats the problem. | | |
