5 members (MickeyP, 68ironhead, Lightholder's Dad, JoergK., EchoBravoSierra), 57 guests, and 3 robots.
Topics128,175
Posts1,057,119
Members48,463
I have myself a lead on a 1995 chevy 350 tbi engine block for a good price, and I was wondering, just how much can swap across? I'm mostly interested in the oil pan, but anything else would be nice.
I guess you are asking what parts from a TBI engine can be used on the earlier engine. The flywheel has a different bolt pattern, rocker covers have a different bolt pattern, heads and intake manifold have some 90 degree bolt holes, The dip stick is on the opposite side so unlikely the oil pan will switch. Exhaust manifolds will interchange as well as the water pump and pulleys. The TBI engines also have the fuel pump mount blocked off.
Fred
