| | | Forums66 Topics128,172 Posts1,057,105 Members48,463 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2016 Posts: 114 'Bolter | | 'Bolter Joined: Feb 2016 Posts: 114 | I have myself a lead on a 1995 chevy 350 tbi engine block for a good price, and I was wondering, just how much can swap across? I'm mostly interested in the oil pan, but anything else would be nice. | | | | | Joined: Apr 2005 Posts: 2,102 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,102 | I guess you are asking what parts from a TBI engine can be used on the earlier engine. The flywheel has a different bolt pattern, rocker covers have a different bolt pattern, heads and intake manifold have some 90 degree bolt holes, The dip stick is on the opposite side so unlikely the oil pan will switch. Exhaust manifolds will interchange as well as the water pump and pulleys. The TBI engines also have the fuel pump mount blocked off. Fred
