3 members (klhansen, Nick in Manitou, UtahYork), 82 guests, and 4 robots.
Topics128,080
Posts1,055,953
Members48,430
#1168114 06/04/2016 11:29 AM
I have a 1953 Chevy truck with a later model 235 and I have a water leak . My question is there and water behind the timing chain cover or the motor mount plate ?
sal moreno #1168120 06/04/2016 1:05 PM
sal,
There is no 216/235/261 chain - truck cam/crank timing gears.
There is no water around the timing gears, inside the cover.
Someone else will post info about the front plate being sealed against a water journal opening in the block.
sal moreno #1168130 06/04/2016 3:30 PM
look at the water pump. The gasket or the seal on the shaft is probably leaking.
Tommy
59 apache 1/2t
261 short stepside
tclederman #1168131 06/04/2016 3:31 PM
Ok Thxs . What do u mean about the front plate being sealed again a water journal opening in the block.
tclederman #1168132 06/04/2016 3:32 PM
info what do u mean the front plate being sealed again a water journal opening in the block.
sal moreno #1168141 06/04/2016 4:40 PM
sal,
I poorly stated that comment: "Someone else will post info about the front plate being sealed against a water journal opening in the block."
I should have put an "if - is" in the sentence: "Someone else will post info if the front plate is sealed against a water journal opening in the block."
Sorry,
tclederman #1168143 06/04/2016 4:50 PM
Is there a water hole/journal behind the front mounting plate? I can't find any pictures.
sal moreno #1168144 06/04/2016 5:00 PM
There is a soft plug in the block just below the water pump that could be leading.
There is no water behind the timing plate.
My Blog
Pre '68 Dave #1168146 06/04/2016 5:09 PM
Do u have a picture of this soft plug ? Can it be fixed without taking the motor back out of the truck ?
sal moreno #1168165 06/04/2016 8:51 PM
Here is a picture of the front of a bare block, without the soft-plug installed.
It would be necessary to pull the water pump, and most likely the radiator to replace the soft-plug.
My Blog
sal moreno #1168166 06/04/2016 8:55 PM
I would suggest looking at the weep hole on the bottom of the water pump with a mirror for leaking before doing anything else.
My Blog
Pre '68 Dave #1168172 06/04/2016 9:37 PM
Ok thank you
