6 members (Oswald, farmallb, Stovebolt48, GrandpasJimmy, 2 invisible), 132 guests, and 2 robots.
Topics128,089
Posts1,055,988
Members48,430
#1168089 06/04/2016 3:05 AM
7
7 Offline
I have restored a 1950 1300 Chevrolet 5 window back to factory built condition.
It has one left tail light for running and brake.
I am considering putting turn signals onto it. Did these trucks have that option available ? Does anyone know where I can see pics of the parts that I'll need to do the install?
Thanks John.
1950 Chevrolet 1300 - Canadian Built
This truck is now for sale (9/2016)
All Original
More pix in Bolt Bucket
John,
There was no factory-option turn signals in 1950, but there were GM accessory turn-signal switches/lamps (very rare).
Parts vendors sell right rear lamps and hangers.
Some vendors sell turn-signal switches (look in "Links"). The can be used with 6v or 12v bulbs.
John,
what have members done for dash indicators for turn signals?
Also, FAM shows a ignition switch bulb in the igniton bracket,but that is behind the dash,what does it light ?
just-a-hacker
'49 3100 before '99
The ignition switch bulb dimly lights the ignition switch.
In 1954, there was one signal indicator light - at middle bottom of the speedometer gauge.
For the accessory turn signal unit you need to look for the Guide 6004 (color and applications differ).
https://www.flickr.com/photos/advance-design_parts_co/8129435258/in/album-72157631868452754/
https://www.flickr.com/photos/advance-design_parts_co/8129416019/in/album-72157631868452754/
https://www.flickr.com/photos/advance-design_parts_co/8129328270/in/album-72157631868452754/
A RH light option was available, only a couple of states Oregon and Washington I believe required them in this period of time. This optional item in NOS for 1947-53 is very rare. The RH light was not furnished in the accessory signal kits I have owned. Companies other than guide offered these lights here is one example.
https://www.flickr.com/photos/advance-design_parts_co/16201073413/in/album-72157631868452754/
The later '54 style kit came with everything needed for the conversion (rear).
https://www.flickr.com/photos/advance-design_parts_co/22702548351/in/album-72157631868452754/
The separate '54 light was also offered separately from the signal kit and is more common NOS but not cheap.
https://www.flickr.com/photos/advance-design_parts_co/15240467973/in/album-72157631868452754/
There were many different styles of aftermarket signal kits available, here is one example. These are very common NOS on eBay and at Swap Meets.
https://www.flickr.com/photos/advance-design_parts_co/16453032716/in/album-72157631868452754/
Period advertising showing front fender signals on a GMC. Lights in mounted locations are rare in the factory literature.
https://www.flickr.com/photos/advance-design_parts_co/15305984747/in/album-72157631872034068/
A shot from the 1954 Silver Book, several examples can be found in the Silver Books.
https://www.flickr.com/photos/advance-design_parts_co/16273739804/in/album-72157631872034068/
1953 mailer/dealer handout.
https://www.flickr.com/photos/advance-design_parts_co/23903473622/in/album-72157631872034068/
7
7 Offline
Great info.
Thanks to all.
John.
All Original
Leo Offline
Moderator
Moderator
[/quote]
My signal-stat 900 has indicator lights on the unit.
