3 members (Bill Hanlon, klhansen, 1 invisible),
51
Mod | | | Forums66 Topics128,024 Posts1,055,395 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2005 Posts: 364 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 364 | Does anyone know the PPG paint code for the "Champaign" interior color for AD trucks?
Keith If it were easy they'd have grade schoolers doing it! | | | | | Joined: May 2003 Posts: 213 'Bolter | | 'Bolter Joined: May 2003 Posts: 213 | At this point, there is none. All seem to be lost. A couple of the big vendors (Chevy Duty, Jim Carter) sell an enamel that is supposed to be a very good match. If somebody had some we could scan and have matched, we'd have it, but until then, a guess is as good as it gets. Maybe if enough of us ask they will formulate in modern formulas too. I'd give who knows what to get a PPG single stage to use. I'm not holding out for perfect either.
I think a current Audi color (Dakar Beige???) is close. I may have some mixed to see for sure. I've bought all the rattle cans of colors that seem comparable, but current colors haven't shown any good matches.
Anybody else with thoughts on this one? | | | | | Joined: Mar 2005 Posts: 158 Shop Shark | | Shop Shark Joined: Mar 2005 Posts: 158 | Drop a note to Bob Adler. [email protected]He can help with this. Cheers, mark. '51 3100 | | | | | Joined: Jan 2005 Posts: 364 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 364 | I e-mailed Bob Adler and this is what he sent me... __________________________________________________ Keith, The 47-53 Chev truck interiors were gray-brown metallic, not champaign. I put some of my database below. I sell the complete paint info pack for $20. I don't have DAR, but your paint store should be able to convert. I'm changing all my lacquer numbers to DCC Concept acrylic urethane, a better binder. I'll put my sales pitch below, too. Bob
Steering col. 1947-53 27627 Steering wheel, column, and gearshift remote control Steering col. DuPont 1947-53 DuP 8540 Steering wheel, column, and gearshift remote control Interior Slate Grey 1947-52 DDL3613 Looks brown met. Cabs only? J. Carter PT107 or DCC5558 Also DuP C8306. Add flattener _________________________________________________ I hope this helps anyone else who may have the same question I did.
Keith If it were easy they'd have grade schoolers doing it! | | | | | Joined: Jan 2005 Posts: 1,602 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 1,602 | Pakrat47: I was searching the web site and came across this old posted exchange. I have to ask did you paint your truck with the codes above and were they the correct interior colors? I've seen many colors used but Mr. Adler was correct about the gray-brown metalic color being in my old 51 firetruck. I just want to match it up with the right color. | | | | | Joined: Jan 2005 Posts: 364 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 364 | VA., I went with PPG DIU3550. It's actually listed as a 1983-84 GM color "Lt. Briar Brown Poly". I think it's an excellent match to original.
I need to get myself a dig. camera so I can post some pictures of this kind of stuff. :rolleyes:
Keith If it were easy they'd have grade schoolers doing it! | | | | | Joined: Jan 2005 Posts: 364 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 364 | BTW, DIU is just DBU basecoat that you don't clearcoat.
Keith If it were easy they'd have grade schoolers doing it! | | | | | Joined: Jan 2005 Posts: 1,602 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 1,602 | Yep...you need a digital camera. I want to see it in color. If you weren't so far away, I'd drive over to visit with you. | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Well I'm tryin to follow this but your loosing me with all the acronyms. What's a DIU or a DBU? I was gonna send Bob Adler $20, but if that is the kind of mumbo jumbo that he is gonna send me, I'm not wastin the money. I understand these are paint numbers but other than the ones prefixed with DuP, and PPG I'm in the dark.
Which is it, a 27626 (Unkbown Manufactuer?) or is it DuP 8540? What’s a DCL 3613 or a DCC5558, is that a Dupont number?
And then in the end we end up with PPG DIU3550 which,was not sugested by Bob A., J.C. or Chevy Duty? Maybe I'll get this jargon after I have been around a little longer, but can ya help me out here and now?
Denny Graham Sandwich, IL
Denny G Sandwich, IL
| | | | | Joined: Jan 2001 Posts: 428 Shop Shark | | Shop Shark Joined: Jan 2001 Posts: 428 | Denny, They are just the different types of paint from the supplier. DCC and DCL are PPG paints. DCC is Concept single stage urethane and I believe DCL is laquer. Me thinks Adler only supplies the numbers for Dupont and PPG paints, but a jobber shoould be able to cross reference in any brand. I've been getting my PPG from a place in Orland Park, but that's probably a little far for you. Sure is expensive though. Bob | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Thanks Bob, I probably need to stop by the PPG dealer here (closest is in Aurora) and pick up some literature so I know what the different lines of paint have to offer. My body shop buddy, (doesn't everyone have one of those) only uses PPG and he is always bending my ear about the high cost of their paint now days. I won’t be ready for paint till, I’m hoping, next summer. But I like to stay ahead of the game, so I’m starting “Paint 101” now. I painted my Pitts Special Biplane and a bunch of vintage motorcycles way back when, but I haven’t done any spraying for quite some. Dulux, Centari , Imeron were some of the paint lines that were around back then, a lot has changed since then. Denny Graham Sandwich, IL
| | | | | Joined: Jan 2005 Posts: 364 Shop Shark | | Shop Shark Joined: Jan 2005 Posts: 364 | Denny, The only paint line I have had any real experience with is PPG. The letters I listed are actually PPG paint prefixes and not acronyms. PPG prefixes are as follows... DAR-single stage acrylic enamel DAU-single stage acrylic urethane DBU-universal basecoat DCC-Concept acrylic urethane PPG also has a line of less expensive products called OMNI. I have used these products with very good results. Here is a link to PPG's website. Hope this helps.
Keith If it were easy they'd have grade schoolers doing it! | | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | Thanks Keith, I've book marked the PPG site and will be devoting some study time to it. I'm learnin', slowly but surely. Maybe by the time I’m ready to start on the cosmetics I’ll have a handle on it. My body shop buddy has been giving up a little information on paints and painting systems from PPG, but I have to pry every little bit of it out of him. You know how a lot of people are reluctant to let you know their SECRETS! Denny Graham Sandwich, IL
