| | | Forums66 Topics128,077 Posts1,056,280 Members48,441 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Dec 2012 Posts: 163 'Bolter | | 'Bolter Joined: Dec 2012 Posts: 163 | As stated before the plugs were replaced 3-4 years ago and now the rear just started to leak. About 3 drops per day when cold but I started the truck and let it idle for about 30 minutes and it did not leak at all! Now after sitting for 2 days it just now started to leak again about the same amount. Does this make any sense to anyone? Thanks, Howard | | | | | Joined: Mar 2010 Posts: 10,282 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,282 | Barsleak cannot hurt anything. It will likely solve this minor, intermittent leak. If it doesn't stop the leak, you are only out a few dollars. Carl
| | | | | Joined: Dec 2012 Posts: 163 'Bolter | | 'Bolter Joined: Dec 2012 Posts: 163 | Thanks. I will probably give it a little more time to maybe seal itself up and then use the stopleak if necessary. Howard | | |
