4 members (Hotrod Lincoln, Guitplayer, TUTS 59, IHPWR), 185 guests, and 1 robot.
Topics128,108
Posts1,056,227
Members48,436
As stated before the plugs were replaced 3-4 years ago and now the rear just started to leak. About 3 drops per day when cold but I started the truck and let it idle for about 30 minutes and it did not leak at all! Now after sitting for 2 days it just now started to leak again about the same amount. Does this make any sense to anyone?
Howard
Barsleak cannot hurt anything. It will likely solve this minor, intermittent leak. If it doesn't stop the leak, you are only out a few dollars.
Carl
Thanks. I will probably give it a little more time to maybe seal itself up and then use the stopleak if necessary.
Howard
