| | | Forums66 Topics128,051 Posts1,055,734 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2007 Posts: 31 'Bolter | | 'Bolter Joined: Oct 2007 Posts: 31 | How do I tell what I've got under my 51 truck? I am told it was out of a 57 van with auto trans but I want to convert to 3;73 POSI, retaining the 6 lug bolt pattern, so I am wondering where to find the numbers to look up? | | | | | Joined: May 2006 Posts: 8,351 'Bolter | | 'Bolter Joined: May 2006 Posts: 8,351 | If it's out of a Chevrolet, the numbers are stamped on the passenger side of the front of the third member, between two of the mounting holes near the axle tube. If you can, you might post a pic of it just in case it isn't a Chevrolet differential. That would make it easier to give an identification and to tell you where to look for numbers for verification.
Bill Burmeister | | |
