| | | Forums66 Topics128,091 Posts1,056,038 Members48,433 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2015 Posts: 19 New Guy | | New Guy Joined: Nov 2015 Posts: 19 | I have just been offered a 1967 Camero 10 bolt axle in excellent condition, i am currently running a 12 bolt axle at the moment how easy is it to swap over | | | | | Joined: Apr 2005 Posts: 7,440 Bolter | | Bolter Joined: Apr 2005 Posts: 7,440 | Why? Is your current 12 bolt bad? Swap is fairly straight forward. The 12 bolt is reported to be stronger.
| | | | | Joined: Nov 2015 Posts: 19 New Guy | | New Guy Joined: Nov 2015 Posts: 19 | I'm running with a 3.73 and want to be able to cruise at around 65 to 70 on the motorways here with lower revs, tried putting a 3.42 and a 3.08 in and they don't fit due to the case size which wont allow my half shafts to fit in so that's why I was thinking about the Camero especially when its £300 | | | | | Joined: Feb 2000 Posts: 5,212 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 5,212 | The Camaro axle will be narrower then the truck axle, internals will not swap. Most likely the bolt pattern will be different, car will have 5 lug, truck will have 6 or even 8. | | | | | Joined: Jun 2011 Posts: 5,096 Crusing in the Passing Lane | | Crusing in the Passing Lane Joined: Jun 2011 Posts: 5,096 | Stick with your 12 bolt, there are lots of parts for them, stronger. Might to have to ship from 'States.'
Ed
