0 members (), 145 guests, and 5 robots.
Topics128,078
Posts1,056,049
Members48,433
#1167601 05/31/2016 11:34 AM
I have just been offered a 1967 Camero 10 bolt axle in excellent condition, i am currently running a 12 bolt axle at the moment how easy is it to swap over
Why? Is your current 12 bolt bad? Swap is fairly straight forward. The 12 bolt is reported to be stronger.
I'm running with a 3.73 and want to be able to cruise at around 65 to 70 on the motorways here with lower revs, tried putting a 3.42 and a 3.08 in and they don't fit due to the case size which wont allow my half shafts to fit in so that's why I was thinking about the Camero especially when its £300
J Online: Content
The Camaro axle will be narrower then the truck axle, internals will not swap. Most likely the bolt pattern will be different, car will have 5 lug, truck will have 6 or even 8.
Crusing in the Passing Lane
Stick with your 12 bolt, there are lots of parts for them, stronger. Might to have to ship from 'States.'
Ed
