| | | Forums66 Topics128,079 Posts1,056,309 Members48,442 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jul 2015 Posts: 39 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2015 Posts: 39 | hello, ive got a 68 gmc 2 ton that i am going through the brake system on right now its got the 14" x 2.5" brake shoes on it . i found the shoes at napa but they would have to order them and they were 86$. also they did not carry nor could they order a hardware kit for these. if someone could send me a link to a website or some part numbers for cheaper brake shoes, hardware kit and wheel cylinders for my truck asap i would appreciate it. thank you | | | | | Joined: Dec 2015 Posts: 2,063 Big Bolt Forum Moderator | | Big Bolt Forum Moderator Joined: Dec 2015 Posts: 2,063 | you may check Rock Auto for wheel cylinders or kits to rebuild them. Is there a local shop that does brake and clutch relining in your area? Here in Seattle we have Brake and Clutch Supply that will reline your old shoes.
For Napa part #s, their UP # will translate to a Raybestos # to plug into Rock Auto. Napa UP129 (wheel cylinder kit) is the same as Raybestos WK129 | | | | | Joined: Jul 2015 Posts: 39 Wrench Fetcher | | Wrench Fetcher Joined: Jul 2015 Posts: 39 | thank you for the reply. I ended up going with Napa and got all the stuff I needed pretty reasonably priced
