3 members (Opelika Tom, 2 invisible), 95 guests, and 0 robots.
Topics128,134
Posts1,056,402
Members48,441
I
I Offline
hello, ive got a 68 gmc 2 ton that i am going through the brake system on right now its got the 14" x 2.5" brake shoes on it . i found the shoes at napa but they would have to order them and they were 86$. also they did not carry nor could they order a hardware kit for these. if someone could send me a link to a website or some part numbers for cheaper brake shoes, hardware kit and wheel cylinders for my truck asap i would appreciate it. thank you
Big Bolt Forum Moderator
you may check Rock Auto for wheel cylinders or kits to rebuild them. Is there a local shop that does brake and clutch relining in your area? Here in Seattle we have Brake and Clutch Supply that will reline your old shoes.
For Napa part #s, their UP # will translate to a Raybestos # to plug into Rock Auto. Napa UP129 (wheel cylinder kit) is the same as Raybestos WK129
Mike
I
I Offline
thank you for the reply. I ended up going with Napa and got all the stuff I needed pretty reasonably priced
